Capacitor ?
Ok I was out of town for a few days but I'm on it again right now I'm running it off a 6v battery, I'm not using the 0Z4 but the diodes you suggested, The filter caps are both 22mf @350v. I couldn't sometimes get the vibrator going so I have been using the Solid State Vibrator ( I figure once this is in the dash he won't be able to smack it to get it going). I've noticed it hums regardless which vibrator I use just the pitch is a little different. Grounding doesn't seem to make a difference. Shrunk the 4' speaker down 4 " not easy, tried a variety of PM speakers but all pretty much the same.
Eric
Capacitor ? - by Eric - 08-10-2016, 09:16 AM
RE: Capacitor ? - by Phlogiston - 08-10-2016, 09:49 AM
RE: Capacitor ? - by Radioroslyn - 08-10-2016, 11:50 AM
RE: Capacitor ? - by Eric - 08-10-2016, 11:57 AM
RE: Capacitor ? - by David - 08-10-2016, 07:35 PM
RE: Capacitor ? - by Eric - 08-12-2016, 02:39 PM
RE: Capacitor ? - by morzh - 08-10-2016, 07:41 PM
RE: Capacitor ? - by Radioroslyn - 08-10-2016, 08:29 PM
RE: Capacitor ? - by morzh - 08-10-2016, 09:07 PM
RE: Capacitor ? - by Eric - 08-11-2016, 02:52 PM
RE: Capacitor ? - by Radioroslyn - 08-12-2016, 08:53 AM
RE: Capacitor ? - by Eric - 08-12-2016, 02:30 PM
RE: Capacitor ? - by Eric - 08-12-2016, 02:36 PM
RE: Capacitor ? - by Radioroslyn - 08-12-2016, 04:22 PM
RE: Capacitor ? - by Eric - 08-14-2016, 10:11 AM
RE: Capacitor ? - by Eric - 08-14-2016, 03:09 PM
RE: Capacitor ? - by Arran - 08-16-2016, 05:27 AM
RE: Capacitor ? - by Radioroslyn - 08-16-2016, 09:47 AM
RE: Capacitor ? - by Eric - 08-18-2016, 01:15 PM
RE: Capacitor ? - by Kenneth F. Besso Jr. - 08-19-2016, 08:56 AM
RE: Capacitor ? - by Eric - 08-19-2016, 10:12 AM
RE: Capacitor ? - by Eric - 08-19-2016, 12:06 PM
RE: Capacitor ? - by Radioroslyn - 08-19-2016, 12:18 PM
RE: Capacitor ? - by Eric - 08-21-2016, 08:47 PM
RE: Capacitor ? - by Radioroslyn - 08-21-2016, 09:46 PM
RE: Capacitor ? - by Eric - 08-22-2016, 05:13 PM
RE: Capacitor ? - by Radioroslyn - 08-22-2016, 06:57 PM
RE: Capacitor ? - by Eric - 08-24-2016, 04:31 PM
RE: Capacitor ? - by Radioroslyn - 08-25-2016, 03:18 PM
RE: Capacitor ? - by Eric - 08-29-2016, 05:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6415 online users. [Complete List]
» 1 Member(s) | 6414 Guest(s)
