Philco 38-690
Thanks for the info. I know that Mark was doing these dials along with Radiodaze, and I had heard that the amber material was gone. I don't know the overall condition of the set yet, so I'm just gathering some preliminary info. I'll hopefully be seeing the radio this week, so I'll know more once I get the chance to look it over.
Philco 38-690 - by jmsent - 08-29-2016, 10:04 AM
RE: Philco 38-690 - by klondike98 - 08-29-2016, 04:45 PM
RE: Philco 38-690 - by jmsent - 08-29-2016, 06:54 PM
RE: Philco 38-690 - by Arran - 08-30-2016, 03:25 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
