Philco 80 jr. rectifier tube hot
Looks to be #19, supplies the dc voltage to the screen grid for the 2nd detector. Some of the block capacitors may have an unused terminal used for a tie point. .09mfd is an odd value so .1mfd is the proper subtitute
Philco 80 jr. rectifier tube hot - by Mike L - 08-28-2016, 04:29 PM
RE: Philco 80 jr. rectifier tube hot - by sam - 08-28-2016, 05:08 PM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 08-30-2016, 08:20 PM
RE: Philco 80 jr. rectifier tube hot - by Radioroslyn - 08-30-2016, 10:27 PM
RE: Philco 80 jr. rectifier tube hot - by Arran - 09-02-2016, 04:50 AM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-03-2016, 10:31 AM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-04-2016, 09:28 AM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-11-2016, 03:06 PM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-12-2016, 07:47 PM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-13-2016, 08:25 PM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-22-2016, 07:45 PM
RE: Philco 80 jr. rectifier tube hot - by morzh - 09-22-2016, 10:06 PM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 09-24-2016, 09:20 AM
RE: Philco 80 jr. rectifier tube hot - by morzh - 10-05-2016, 07:59 AM
RE: Philco 80 jr. rectifier tube hot - by Mike L - 10-05-2016, 07:28 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8056 online users. [Complete List]
» 3 Member(s) | 8053 Guest(s)
