Stromberg Carlson 430M
Quick question.. I have a .04 Cap that will be replaced. What would you use as replacement.. a .033 or a .047
I used the .047 to replace the .05's So I am thinking to use the .033 to replace the .04..
Any preferences?
Skip...
Stromberg Carlson 430M - by vecher - 08-20-2016, 03:42 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 05:47 PM
RE: Stromberg Carlson 430M - by vecher - 08-20-2016, 06:30 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 06:45 PM
RE: Stromberg Carlson 430M - by vecher - 08-22-2016, 03:22 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 03:55 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 06:06 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 08:05 PM
RE: Stromberg Carlson 430M - by Arran - 08-28-2016, 04:22 AM
RE: Stromberg Carlson 430M - by Paul Philco322 - 08-28-2016, 12:02 PM
RE: Stromberg Carlson 430M - by vecher - 08-28-2016, 12:42 PM
RE: Stromberg Carlson 430M - by vecher - 08-31-2016, 10:36 PM
RE: Stromberg Carlson 430M - by gregb - 08-31-2016, 11:25 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:31 AM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 03:11 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:32 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:06 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 12:42 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:12 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 10:35 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:19 PM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 05:10 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:08 PM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 12:43 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-06-2016, 08:29 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 10:38 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 04:33 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 01:30 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 03:42 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-08-2016, 04:05 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 03:12 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-12-2016, 04:20 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 04:53 PM
Users browsing this thread: 15 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
