Another Car Radio Problem
Good thought exray but the slugs are snug. There are still a few moulded mica caps across the slug assembly I didn't touch. I wonder if one of them has a mechanical defect? I just don't trust old mica caps anymore. I suppose I should check whether the trimmer screws in the end of the slugs are too loose. This just seems like an electrical problem instead of a mechanical problem because of the behavior. There are just no mechanical stresses when the problem occurs.
Ron
Another Car Radio Problem - by Retro Ron - 08-12-2009, 10:42 PM
Re: Another Car Radio Problem - by exray - 08-13-2009, 07:37 AM
Re: Another Car Radio Problem - by Retro Ron - 08-15-2009, 10:33 PM
Re: Another Car Radio Problem - by Texasrocker - 08-16-2009, 12:04 AM
Re: Another Car Radio Problem - by Arran - 08-17-2009, 06:44 PM
Re: Another Car Radio Problem - by Retro Ron - 08-24-2009, 02:06 AM
Re: Another Car Radio Problem - by kruc - 08-24-2009, 04:37 AM
Re: Another Car Radio Problem - by BILL - 08-24-2009, 12:42 PM
Re: Another Car Radio Problem - by Retro Ron - 08-30-2009, 06:41 PM
Re: Another Car Radio Problem - by kruc - 08-31-2009, 03:41 AM
Philco 91 Tuning Condenser
