model 16 code 125
Once I removed the chassis, I found a decades old "patchwork pete" repair:
It appears I'm missing a choke?
In its place are two .05 mfd capacitors and two 50K resistors tied to two terminal strips. Not sure how this worked but it must've at one time, judging by how old the caps look.
Can anyone suggest a more proper replacement that would look correct?
model 16 code 125 - by NostalgiaRadioTime - 09-04-2016, 09:04 PM
RE: model 16 code 125 - by morzh - 09-04-2016, 10:16 PM
RE: model 16 code 125 - by Radioroslyn - 09-04-2016, 11:23 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-05-2016, 12:27 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-06-2016, 07:13 PM
RE: model 16 code 125 - by Radioroslyn - 09-06-2016, 09:38 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-06-2016, 10:49 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-07-2016, 09:59 PM
RE: model 16 code 125 - by Steve Davis - 09-07-2016, 11:06 PM
RE: model 16 code 125 - by Radioroslyn - 09-07-2016, 11:17 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-08-2016, 01:31 AM
RE: model 16 code 125 - by Arran - 09-08-2016, 05:05 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-08-2016, 11:14 PM
RE: model 16 code 125 - by Arran - 09-09-2016, 03:36 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-09-2016, 10:25 AM
RE: model 16 code 125 - by Arran - 09-10-2016, 11:51 PM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-09-2016, 05:10 PM
RE: model 16 code 125 - by Radioroslyn - 09-09-2016, 07:50 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-11-2016, 01:27 AM
RE: model 16 code 125 - by Arran - 09-13-2016, 04:08 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-13-2016, 10:31 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 03:38 PM
RE: model 16 code 125 - by Radioroslyn - 09-18-2016, 05:05 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 05:32 PM
RE: model 16 code 125 - by Radioroslyn - 09-18-2016, 07:42 PM
RE: model 16 code 125 - by morzh - 09-18-2016, 09:30 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 10:34 PM
RE: model 16 code 125 - by Ron Ramirez - 09-20-2016, 09:48 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-19-2016, 10:33 PM
RE: model 16 code 125 - by Radioroslyn - 09-19-2016, 11:09 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 07:14 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 10:35 PM
RE: model 16 code 125 - by Radioroslyn - 09-20-2016, 11:14 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 11:34 PM
RE: model 16 code 125 - by Radioroslyn - 09-21-2016, 04:59 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-22-2016, 10:38 PM
RE: model 16 code 125 - by Radioroslyn - 09-23-2016, 01:01 AM
RE: model 16 code 125 - by Ron Ramirez - 09-23-2016, 06:01 AM
RE: model 16 code 125 - by Steve Davis - 09-23-2016, 08:54 AM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-23-2016, 05:00 PM
RE: model 16 code 125 - by Radioroslyn - 09-23-2016, 05:52 PM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-23-2016, 08:26 PM
RE: model 16 code 125 - by Ron Ramirez - 09-24-2016, 12:36 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-26-2016, 06:47 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-27-2016, 10:35 PM
RE: model 16 code 125 - by morzh - 09-28-2016, 11:30 AM
Users browsing this thread: 13 Guest(s)
Restoring Philco 96
There are currently 7492 online users. [Complete List]
» 2 Member(s) | 7490 Guest(s)
