Stromberg Carlson 430M
The short answer is check all of the resistors around the eye tube circuit and the 6K7 IF amp tube. How it works is it's looking at the SG voltage on the 6K7. Where you get a strong signal the AVC circuit kick in and drops the gain of the mixer and IF amp this in turn causes the SG volt to increase because of less current flow. This closes the eye. Also have a look at the AVC voltage could be a weak tube or high value resistor. This tube is a bit different than the normal 6E5,6U5, and 6G5 as these a have there own triode driver in the tube.
Stromberg Carlson 430M - by vecher - 08-20-2016, 03:42 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 05:47 PM
RE: Stromberg Carlson 430M - by vecher - 08-20-2016, 06:30 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 06:45 PM
RE: Stromberg Carlson 430M - by vecher - 08-22-2016, 03:22 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 03:55 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 06:06 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 08:05 PM
RE: Stromberg Carlson 430M - by Arran - 08-28-2016, 04:22 AM
RE: Stromberg Carlson 430M - by Paul Philco322 - 08-28-2016, 12:02 PM
RE: Stromberg Carlson 430M - by vecher - 08-28-2016, 12:42 PM
RE: Stromberg Carlson 430M - by vecher - 08-31-2016, 10:36 PM
RE: Stromberg Carlson 430M - by gregb - 08-31-2016, 11:25 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:31 AM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 03:11 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:32 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:06 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 12:42 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:12 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 10:35 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:19 PM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 05:10 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:08 PM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 12:43 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-06-2016, 08:29 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 10:38 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 04:33 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 01:30 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 03:42 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-08-2016, 04:05 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 03:12 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-12-2016, 04:20 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 04:53 PM
Philco 89 indicator light.
There are currently 9392 online users. [Complete List]
» 1 Member(s) | 9391 Guest(s)
