630 refinishing
Medium Walnut on front panel (not Perfect Brown - too dark), Extra Dark Walnut on the top, sides, and bottom front trim.
630 refinishing - by Steve McDonald - 09-04-2016, 01:58 PM
RE: 630 refinishing - by KCMike - 09-04-2016, 03:32 PM
RE: 630 refinishing - by OldRestorer - 09-04-2016, 04:39 PM
RE: 630 refinishing - by OldRestorer - 09-04-2016, 04:41 PM
RE: 630 refinishing - by Ron Ramirez - 09-05-2016, 10:26 AM
There are currently 7679 online users. [Complete List]
» 1 Member(s) | 7678 Guest(s)
