Stromberg Carlson 430M
Terry, Ok What I understand is The Grids of the 6af6 take anywhere between 80-160 Volts to close. With I assume 160 volts fully closed. Which kind of makes since .. with No signal pin 3 reads 78.7 volts. Or fully open since it takes 80 volts to start to close. But I cannot seem to get anywhere near 160 volts. The strongest signal I can find is only 146 volts.. Maybe there is a way to make this more sensitive?
Ps I did notice that on the plate I was getting 273 volts The range for the tube is 125-250 volts..
My B+ is higher to. according to paper work it should be 382 volts I get 392 Volts..
My field coil should be 1050 Ohms Mine measured 808 Ohms Thats probably why the B+ is a little higher..
Should I try to lower the voltage to the plate of the 6AF6 ? Maybe that would make it work better?
Comments??
Skip...
Stromberg Carlson 430M - by vecher - 08-20-2016, 03:42 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 05:47 PM
RE: Stromberg Carlson 430M - by vecher - 08-20-2016, 06:30 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 06:45 PM
RE: Stromberg Carlson 430M - by vecher - 08-22-2016, 03:22 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 03:55 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 06:06 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 08:05 PM
RE: Stromberg Carlson 430M - by Arran - 08-28-2016, 04:22 AM
RE: Stromberg Carlson 430M - by Paul Philco322 - 08-28-2016, 12:02 PM
RE: Stromberg Carlson 430M - by vecher - 08-28-2016, 12:42 PM
RE: Stromberg Carlson 430M - by vecher - 08-31-2016, 10:36 PM
RE: Stromberg Carlson 430M - by gregb - 08-31-2016, 11:25 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:31 AM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 03:11 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:32 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:06 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 12:42 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:12 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 10:35 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:19 PM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 05:10 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:08 PM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 12:43 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-06-2016, 08:29 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 10:38 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 04:33 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 01:30 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 03:42 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-08-2016, 04:05 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 03:12 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-12-2016, 04:20 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 04:53 PM
Philco 89 indicator light.
There are currently 9340 online users. [Complete List]
» 1 Member(s) | 9339 Guest(s)
