38-3 Chassis in a 38-1 cabinet?
Yup, I hear you on that. I have 5 consoles, and I plan on selling 2. The 38-1 I have is a keeper, as well as the 95 Lowboy and 41-605P, with the record changer intact. The 38-1 has a 12-tube chassis, and sounds great! The 38-3 I know only had a 9 tube chassis, so in that sense, I think that radio in the ad has an inferior chassis in an otherwise really nice cabinet.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: 38-3 Chassis in a 38-1 cabinet? - by PhilcoPhan1936 - 09-06-2016, 07:41 PM
RE: 38-3 Chassis in a 38-1 cabinet? - by Arran - 09-09-2016, 03:26 AM
RE: 38-3 Chassis in a 38-1 cabinet? - by Arran - 09-10-2016, 03:56 AM
RE: 38-3 Chassis in a 38-1 cabinet? - by Jayce - 09-10-2016, 08:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6644 online users. [Complete List]
» 1 Member(s) | 6643 Guest(s)
