model 16 code 125
Thanks for reminding me of that. I'm embarrassed for making such a dumb mistake. I will try a new cap tonight after work.
model 16 code 125 - by NostalgiaRadioTime - 09-04-2016, 09:04 PM
RE: model 16 code 125 - by morzh - 09-04-2016, 10:16 PM
RE: model 16 code 125 - by Radioroslyn - 09-04-2016, 11:23 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-05-2016, 12:27 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-06-2016, 07:13 PM
RE: model 16 code 125 - by Radioroslyn - 09-06-2016, 09:38 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-06-2016, 10:49 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-07-2016, 09:59 PM
RE: model 16 code 125 - by Steve Davis - 09-07-2016, 11:06 PM
RE: model 16 code 125 - by Radioroslyn - 09-07-2016, 11:17 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-08-2016, 01:31 AM
RE: model 16 code 125 - by Arran - 09-08-2016, 05:05 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-08-2016, 11:14 PM
RE: model 16 code 125 - by Arran - 09-09-2016, 03:36 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-09-2016, 10:25 AM
RE: model 16 code 125 - by Arran - 09-10-2016, 11:51 PM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-09-2016, 05:10 PM
RE: model 16 code 125 - by Radioroslyn - 09-09-2016, 07:50 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-11-2016, 01:27 AM
RE: model 16 code 125 - by Arran - 09-13-2016, 04:08 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-13-2016, 10:31 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 03:38 PM
RE: model 16 code 125 - by Radioroslyn - 09-18-2016, 05:05 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 05:32 PM
RE: model 16 code 125 - by Radioroslyn - 09-18-2016, 07:42 PM
RE: model 16 code 125 - by morzh - 09-18-2016, 09:30 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 10:34 PM
RE: model 16 code 125 - by Ron Ramirez - 09-20-2016, 09:48 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-19-2016, 10:33 PM
RE: model 16 code 125 - by Radioroslyn - 09-19-2016, 11:09 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 07:14 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 10:35 PM
RE: model 16 code 125 - by Radioroslyn - 09-20-2016, 11:14 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 11:34 PM
RE: model 16 code 125 - by Radioroslyn - 09-21-2016, 04:59 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-22-2016, 10:38 PM
RE: model 16 code 125 - by Radioroslyn - 09-23-2016, 01:01 AM
RE: model 16 code 125 - by Ron Ramirez - 09-23-2016, 06:01 AM
RE: model 16 code 125 - by Steve Davis - 09-23-2016, 08:54 AM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-23-2016, 05:00 PM
RE: model 16 code 125 - by Radioroslyn - 09-23-2016, 05:52 PM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-23-2016, 08:26 PM
RE: model 16 code 125 - by Ron Ramirez - 09-24-2016, 12:36 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-26-2016, 06:47 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-27-2016, 10:35 PM
RE: model 16 code 125 - by morzh - 09-28-2016, 11:30 AM
Users browsing this thread: 26 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8664 online users. [Complete List]
» 3 Member(s) | 8661 Guest(s)
