Fada NA
I am sorry to say that all radio projects will be going on hold until my work situation improves. I'll be keeping this one though, no worries there.
Fada NA - by Jayce - 09-03-2016, 05:15 PM
RE: Fada NA - by OldRestorer - 09-03-2016, 07:13 PM
RE: Fada NA - by Paul Philco322 - 09-03-2016, 08:41 PM
RE: Fada NA - by Arran - 09-04-2016, 04:07 AM
RE: Fada NA - by SteveG - 09-04-2016, 12:58 PM
RE: Fada NA - by Jayce - 09-04-2016, 05:02 PM
RE: Fada NA - by jerryhawthorne - 09-04-2016, 07:22 PM
RE: Fada NA - by SteveG - 09-04-2016, 08:56 PM
RE: Fada NA - by Jayce - 09-04-2016, 09:53 PM
RE: Fada NA - by Jayce - 09-09-2016, 10:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
