Philco 50 (early) cabinet restoration
Have been gluing a number of spots since the last post.  Here's that syringe I use in addition to those spatulas.  This particular tip is a 2" blunt tip, 14 gauge which is pretty large, smaller would be better in many cases (amazon sells them, look up "dispensing syringe").
[Image: https://www.dropbox.com/s/2cn901oi158yat....jpg?raw=1]
Some veneer chip fixing on the back edge...
[Image: https://www.dropbox.com/s/qvln35x9ymmwkm....jpg?raw=1]
...and stripping the front piece.  Next will be bleaching the water stains out.
[Image: https://www.dropbox.com/s/xcbz6wq62mhu10....jpg?raw=1]
RE: Philco 50 (early) cabinet restoration - by klondike98 - 09-10-2016, 05:55 PM
Philco 91 Tuning Condenser
There are currently 8671 online users. [Complete List]
» 2 Member(s) | 8669 Guest(s)
