Unknown Gilfillan Model
Here's a shot showing the underside of the chassis, showing the film caps changed out, and the retainer for the electrolytics unscrewed and pulled aside.
[Image: https://farm5.staticflickr.com/4280/3503...7212_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:22 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:29 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:34 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:45 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:52 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:57 AM
RE: Unknown Gilfillan Model - by mikethedruid - 01-19-2016, 05:13 AM
RE: Unknown Gilfillan Model - by Arran - 01-19-2016, 05:41 AM
RE: Unknown Gilfillan Model - by Eliot Ness - 01-19-2016, 08:53 PM
RE: Unknown Gilfillan Model - by Paul Philco322 - 01-19-2016, 09:52 PM
RE: Unknown Gilfillan Model - by Arran - 01-20-2016, 02:58 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:03 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:07 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:19 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:20 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:24 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 02:29 AM
RE: Unknown Gilfillan Model - by OldRestorer - 09-11-2016, 08:10 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 07-12-2017, 12:59 AM
RE: Unknown Gilfillan Model - by OldRestorer - 07-12-2017, 11:30 AM
RE: Unknown Gilfillan Model - by Eliot Ness - 07-12-2017, 01:42 PM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 07-13-2017, 02:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
