Unknown Gilfillan Model
I decided to gut the capacitors, and re-use them. You can see the modern cap off to the left. I replaced with a 10ufd, 450v replacement for both. I recycled a cardboard toilet paper core to cut out new ends and glued them in place with the new cap inside.
[Image: https://farm5.staticflickr.com/4281/3503...8890_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:22 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:29 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:34 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:45 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:52 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:57 AM
RE: Unknown Gilfillan Model - by mikethedruid - 01-19-2016, 05:13 AM
RE: Unknown Gilfillan Model - by Arran - 01-19-2016, 05:41 AM
RE: Unknown Gilfillan Model - by Eliot Ness - 01-19-2016, 08:53 PM
RE: Unknown Gilfillan Model - by Paul Philco322 - 01-19-2016, 09:52 PM
RE: Unknown Gilfillan Model - by Arran - 01-20-2016, 02:58 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:03 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:07 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:19 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:20 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:24 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 02:29 AM
RE: Unknown Gilfillan Model - by OldRestorer - 09-11-2016, 08:10 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 07-12-2017, 12:59 AM
RE: Unknown Gilfillan Model - by OldRestorer - 07-12-2017, 11:30 AM
RE: Unknown Gilfillan Model - by Eliot Ness - 07-12-2017, 01:42 PM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 07-13-2017, 02:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
