Stromberg Carlson 430M
#37
Yup, If the top looked as good as the sides I would be in business..
Skip..
Well I think I will put radio back in to see how it looks.. and sounds..I can always take it out again if I need to do more to cabinet..
Skip...
Stromberg Carlson 430M - by vecher - 08-20-2016, 03:42 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 05:47 PM
RE: Stromberg Carlson 430M - by vecher - 08-20-2016, 06:30 PM
RE: Stromberg Carlson 430M - by gregb - 08-20-2016, 06:45 PM
RE: Stromberg Carlson 430M - by vecher - 08-22-2016, 03:22 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 03:55 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 06:06 PM
RE: Stromberg Carlson 430M - by vecher - 08-27-2016, 08:05 PM
RE: Stromberg Carlson 430M - by Arran - 08-28-2016, 04:22 AM
RE: Stromberg Carlson 430M - by Paul Philco322 - 08-28-2016, 12:02 PM
RE: Stromberg Carlson 430M - by vecher - 08-28-2016, 12:42 PM
RE: Stromberg Carlson 430M - by vecher - 08-31-2016, 10:36 PM
RE: Stromberg Carlson 430M - by gregb - 08-31-2016, 11:25 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:31 AM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 03:11 PM
RE: Stromberg Carlson 430M - by vecher - 09-04-2016, 11:32 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:06 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 12:42 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:12 AM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 10:35 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 12:19 PM
RE: Stromberg Carlson 430M - by vecher - 09-05-2016, 05:10 PM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-05-2016, 08:08 PM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 12:43 AM
RE: Stromberg Carlson 430M - by Radioroslyn - 09-06-2016, 08:29 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 10:38 AM
RE: Stromberg Carlson 430M - by vecher - 09-06-2016, 04:33 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 01:30 PM
RE: Stromberg Carlson 430M - by vecher - 09-08-2016, 03:42 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-08-2016, 04:05 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 03:12 PM
RE: Stromberg Carlson 430M - by klondike98 - 09-12-2016, 04:20 PM
RE: Stromberg Carlson 430M - by vecher - 09-12-2016, 04:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6308 online users. [Complete List]
» 1 Member(s) | 6307 Guest(s)
