Philco model 77
This is a model 77 chassis that is in a model 96 or similar cabinet. I have fixed some of the questionable caps but and done some testing but all I get is just a light hum no radio at all. I probably need to find out if this is the correct speaker for this chassis. I'll include photos. Tube numbers for this model is #80, 3 24A's, 27, and 2 45's.
Philco model 77 - by flatheadjr - 09-14-2016, 10:24 PM
RE: Philco model 77 - by flatheadjr - 09-14-2016, 10:25 PM
RE: Philco model 77 - by Arran - 09-16-2016, 03:17 AM
RE: Philco model 77 - by flatheadjr - 09-16-2016, 09:52 PM
RE: Philco model 77 - by Arran - 09-17-2016, 03:50 AM
RE: Philco model 77 - by flatheadjr - 09-17-2016, 08:25 PM
RE: Philco model 77 - by Radioroslyn - 09-17-2016, 09:21 PM
RE: Philco model 77 - by flatheadjr - 09-17-2016, 09:38 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 12:08 AM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 12:47 AM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 02:52 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 04:12 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 04:46 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 06:11 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 07:37 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 08:56 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 11:56 PM
RE: Philco model 77 - by flatheadjr - 09-19-2016, 12:20 PM
RE: Philco model 77 - by Radioroslyn - 09-19-2016, 01:09 PM
RE: Philco model 77 - by klondike98 - 09-19-2016, 03:01 PM
RE: Philco model 77 - by flatheadjr - 09-20-2016, 09:52 AM
RE: Philco model 77 - by flatheadjr - 09-20-2016, 11:25 PM
RE: Philco model 77 - by flatheadjr - 01-11-2017, 09:14 PM
RE: Philco model 77 - by Ron Ramirez - 01-11-2017, 09:55 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6231 online users. [Complete List]
» 4 Member(s) | 6227 Guest(s)
AvatarAvatarAvatarAvatar
