Philco 50 (early) cabinet restoration
When I did Mikes, I did tone the column indents. Yours looks like it was too.
I cheated. I toned the whole area then rubbed off the toner on the outer areas Icon_lol
Off to Terry's house..
See you guys there or see you all on Sunday on here...
Me
RE: Philco 50 (early) cabinet restoration - by OldRestorer - 09-15-2016, 02:15 AM
Philco 91 Tuning Condenser
There are currently 8903 online users. [Complete List]
» 2 Member(s) | 8901 Guest(s)
