A trimmer adjustment tool.
Mine showed up yesterday and it looks good, not just thrown together. Even the ends of the handle are beveled. I could make one also, but that takes time and some trial and error. I don't mind paying a little for something that has already had that done, and I can just grab and use when needed. Mike is right about the fact this if not just for those trimmers with B+. Anyone here that has ever done an alignment with a metal nutdriver knows how much fun it is to try adjusting a padder and constantly having to guess where it is set, then remove the driver just to find it changes each time. Sure, you can do it this way - but why fight it when you don't need to?
PS: I mentioned this phorum to Tom and he seemed to indicate if there is enough interest that he would be willing to tool up and make another run of these.
Tim
A trimmer adjustment tool. - by morzh - 09-08-2016, 04:07 PM
RE: A trimmer adjustment tool. - by klondike98 - 09-08-2016, 04:13 PM
RE: A trimmer adjustment tool. - by morzh - 09-08-2016, 10:21 PM
RE: A trimmer adjustment tool. - by klondike98 - 09-09-2016, 08:15 AM
RE: A trimmer adjustment tool. - by morzh - 09-09-2016, 02:17 PM
RE: A trimmer adjustment tool. - by TV MAN - 09-10-2016, 12:05 PM
RE: A trimmer adjustment tool. - by klondike98 - 09-12-2016, 02:05 PM
RE: A trimmer adjustment tool. - by morzh - 09-12-2016, 02:50 PM
RE: A trimmer adjustment tool. - by TV MAN - 09-13-2016, 01:20 PM
RE: A trimmer adjustment tool. - by TV MAN - 09-13-2016, 10:50 PM
RE: A trimmer adjustment tool. - by Joe Rossi - 09-18-2016, 10:14 PM
RE: A trimmer adjustment tool. - by Arran - 09-15-2016, 03:39 AM
RE: A trimmer adjustment tool. - by morzh - 09-15-2016, 08:30 AM
RE: A trimmer adjustment tool. - by TV MAN - 09-16-2016, 08:02 AM
RE: A trimmer adjustment tool. - by morzh - 09-18-2016, 10:34 PM
