I can't find schematic model 82
Dan from what I can tell the 40-82 is a battery/portable.
http://www.nostalgiaair.org/Resources/do...013382.pdf
Check out first paragraph on right.
I can't find schematic model 82 - by Dan Walker - 09-16-2016, 07:32 PM
RE: I can't find schematic model 82 - by KCMike - 09-16-2016, 09:33 PM
RE: I can't find schematic model 82 - by KCMike - 09-16-2016, 09:48 PM
RE: I can't find schematic model 82 - by winniefs - 08-05-2017, 11:29 AM
RE: I can't find schematic model 82 - by winniefs - 08-06-2017, 05:28 PM
The speaker table error?
Philco 70 antenna lead
