Philco 16B (Early Version) - Help Identify Correct Knobs
Last week I purchased a Philco 16B (tombstone, early version) from a local radio enthusiast who is culling his life-long collection. An unusual find in southern California!
The radio is missing all four hex knobs. Yesterday I received three hex knobs from the seller. I’d like to know if these knobs match the original knobs. I also have questions regarding the missing fourth knob (tuning).
FYI, the early 16B has one top knob for tuning. The two outer bottom knobs are for volume and tone. The center bottom knob is for band switch. In a past post, Ron stated, “The tuning knob should be a large hex knob, with a set screw so that the two-speed tuning of the 16-121 chassis can be accomplished easily. The band switch knob should also be a large hex knob. The volume and tone knobs are small hex knobs.”
Bottom Knobs: The three knobs from the seller are black with spring fasteners (no set screws). Two measure 7/8-inch from vertex to vertex (or point to point, as opposed to flat edge to flat edge). The large knob measures 1 1/8 inch. The seller’s knobs look like those in the eBay photo below. Are the seller’s knobs the correct color and size?
Tuning Knob: I’ve seen two types of tuning knobs online. One type looks like the knob with the set screw in the photo below (top photo, second from left; bottom photo top left)). Note that the back of the knob tapers. (This knob matches the tuning knob on my early production 144B. I wonder if they have the same part number.) The other type looks like the large hex knob in the photo below but with a set screw. Which is the correct knob?
Please dust off your early 16Bs and let me know your thoughts. Thanks!
Philco 16B (Early Version) - Help Identify Correct Knobs - by Allen in SB - 09-17-2016, 12:06 AM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4852 online users. [Complete List]
» 2 Member(s) | 4850 Guest(s)
