Philco model 77
Well hmmmmm. Have you replaced any of the caps in the power supply? HV seems good but the bias voltage is pretty low. Try measuring the voltage from pin 1 or 4 to pin 3 w/ the neg lead at 1 or 4 and the plus at pin 3. See if you get a higher reading there for the bias voltage. Seems like your driver and output transformers are good. Both 45's should have the same voltage on the plate, I would suspect that one of your 45's is weak ( the one w/the higher plate voltage). You can try switching the two tubes around and see if same tube have higher voltage on it in the other socket. We need to sort the bias voltage issue out as it's causing the 45's to draw current than they need to.
Philco model 77 - by flatheadjr - 09-14-2016, 10:24 PM
RE: Philco model 77 - by flatheadjr - 09-14-2016, 10:25 PM
RE: Philco model 77 - by Arran - 09-16-2016, 03:17 AM
RE: Philco model 77 - by flatheadjr - 09-16-2016, 09:52 PM
RE: Philco model 77 - by Arran - 09-17-2016, 03:50 AM
RE: Philco model 77 - by flatheadjr - 09-17-2016, 08:25 PM
RE: Philco model 77 - by Radioroslyn - 09-17-2016, 09:21 PM
RE: Philco model 77 - by flatheadjr - 09-17-2016, 09:38 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 12:08 AM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 12:47 AM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 02:52 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 04:12 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 04:46 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 06:11 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 07:37 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 08:56 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 11:56 PM
RE: Philco model 77 - by flatheadjr - 09-19-2016, 12:20 PM
RE: Philco model 77 - by Radioroslyn - 09-19-2016, 01:09 PM
RE: Philco model 77 - by klondike98 - 09-19-2016, 03:01 PM
RE: Philco model 77 - by flatheadjr - 09-20-2016, 09:52 AM
RE: Philco model 77 - by flatheadjr - 09-20-2016, 11:25 PM
RE: Philco model 77 - by flatheadjr - 01-11-2017, 09:14 PM
RE: Philco model 77 - by Ron Ramirez - 01-11-2017, 09:55 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8531 online users. [Complete List]
» 1 Member(s) | 8530 Guest(s)
