Philco model 77
After doing a little looking around methinks your opt is bad. Should be about 550 ohms end to end not 3.1K. That's why there is such an imbalance between the plate voltage on the 45 tubes. I can't seem to locate a pin out for the spkr plug but the combination of any two pin should yield a resistance of 3.4K (field coil), or 275 ohms (ct to plate), or 550 ohms (end to end of the opt), or 3.9K (fc+1/2 of opt primary). Unplug spkr when measuring.
Philco model 77 - by flatheadjr - 09-14-2016, 10:24 PM
RE: Philco model 77 - by flatheadjr - 09-14-2016, 10:25 PM
RE: Philco model 77 - by Arran - 09-16-2016, 03:17 AM
RE: Philco model 77 - by flatheadjr - 09-16-2016, 09:52 PM
RE: Philco model 77 - by Arran - 09-17-2016, 03:50 AM
RE: Philco model 77 - by flatheadjr - 09-17-2016, 08:25 PM
RE: Philco model 77 - by Radioroslyn - 09-17-2016, 09:21 PM
RE: Philco model 77 - by flatheadjr - 09-17-2016, 09:38 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 12:08 AM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 12:47 AM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 02:52 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 04:12 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 04:46 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 06:11 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 07:37 PM
RE: Philco model 77 - by flatheadjr - 09-18-2016, 08:56 PM
RE: Philco model 77 - by Radioroslyn - 09-18-2016, 11:56 PM
RE: Philco model 77 - by flatheadjr - 09-19-2016, 12:20 PM
RE: Philco model 77 - by Radioroslyn - 09-19-2016, 01:09 PM
RE: Philco model 77 - by klondike98 - 09-19-2016, 03:01 PM
RE: Philco model 77 - by flatheadjr - 09-20-2016, 09:52 AM
RE: Philco model 77 - by flatheadjr - 09-20-2016, 11:25 PM
RE: Philco model 77 - by flatheadjr - 01-11-2017, 09:14 PM
RE: Philco model 77 - by Ron Ramirez - 01-11-2017, 09:55 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 3885 online users. [Complete List]
» 1 Member(s) | 3884 Guest(s)
