NEW: Superior TV-11 Tube Tester
Funny you should ask that. Here are 2 pictures of the Line adjust Pot..
[Image: http://i292.photobucket.com/albums/mm38/...5evoss.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...pdkpdm.jpg]
Clearly not a 250 ohm 25 Watt RHEOSTAT. It measured 5 K.. But a interesting story.. At first it measured 3 Ohms.. and from center to to end about 1K to 0 ohms.. Same way other direction... I took it apart and cleaned it and now measures 5 K.. the way it should..
Anyway I ordered a replacement. a 250 ohm 25 Watt RHEOSTAT.
So waiting on the pot...
But more to follow...
Skip...
NEW: Superior TV-11 Tube Tester - by vecher - 09-20-2016, 01:08 PM
RE: NEW: Superior TV-11 Tube Tester - by morzh - 09-20-2016, 01:14 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-20-2016, 04:13 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-20-2016, 05:46 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-22-2016, 04:53 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-22-2016, 08:45 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-23-2016, 11:25 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-24-2016, 08:44 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-25-2016, 10:28 PM
RE: NEW: Superior TV-11 Tube Tester - by morzh - 09-26-2016, 08:20 AM
Eico 232 VTVM Schematic
