NEW: Superior TV-11 Tube Tester
Big Grin
Ok, Just received the new Line adjust Rheostat. It cost me almost as much as I paid for the tube tester...
[Image: http://i292.photobucket.com/albums/mm38/...v1ekhi.jpg]
Before I install I want to check the BY1 rectifier. In schematic it say its Drawn backwards. So how would I test it.. I assume its like any other Diode? but really not sure.. I want to make sure its not shorted so I do not burn out the new Rheostat.. Can it be replaced with a modern diode? If so how?
Skip...
NEW: Superior TV-11 Tube Tester - by vecher - 09-20-2016, 01:08 PM
RE: NEW: Superior TV-11 Tube Tester - by morzh - 09-20-2016, 01:14 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-20-2016, 04:13 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-20-2016, 05:46 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-22-2016, 04:53 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-22-2016, 08:45 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-23-2016, 11:25 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-24-2016, 08:44 PM
RE: NEW: Superior TV-11 Tube Tester - by vecher - 09-25-2016, 10:28 PM
RE: NEW: Superior TV-11 Tube Tester - by morzh - 09-26-2016, 08:20 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 6493 online users. [Complete List]
» 2 Member(s) | 6491 Guest(s)
