model 16 code 125
#38
Those 6287-F and similar 0.3 uF blocks actually contain two 0.15 uF caps wired in partial parallel (one end common and wired together internally, the other two ends wired together at the terminals). A new 0.33 uF film cap probably won't fit in the block, but two new 0.15 uF film caps will (barely) fit inside...which is probably why Philco did it that way to begin with.
model 16 code 125 - by NostalgiaRadioTime - 09-04-2016, 09:04 PM
RE: model 16 code 125 - by morzh - 09-04-2016, 10:16 PM
RE: model 16 code 125 - by Radioroslyn - 09-04-2016, 11:23 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-05-2016, 12:27 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-06-2016, 07:13 PM
RE: model 16 code 125 - by Radioroslyn - 09-06-2016, 09:38 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-06-2016, 10:49 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-07-2016, 09:59 PM
RE: model 16 code 125 - by Steve Davis - 09-07-2016, 11:06 PM
RE: model 16 code 125 - by Radioroslyn - 09-07-2016, 11:17 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-08-2016, 01:31 AM
RE: model 16 code 125 - by Arran - 09-08-2016, 05:05 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-08-2016, 11:14 PM
RE: model 16 code 125 - by Arran - 09-09-2016, 03:36 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-09-2016, 10:25 AM
RE: model 16 code 125 - by Arran - 09-10-2016, 11:51 PM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-09-2016, 05:10 PM
RE: model 16 code 125 - by Radioroslyn - 09-09-2016, 07:50 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-11-2016, 01:27 AM
RE: model 16 code 125 - by Arran - 09-13-2016, 04:08 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-13-2016, 10:31 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 03:38 PM
RE: model 16 code 125 - by Radioroslyn - 09-18-2016, 05:05 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 05:32 PM
RE: model 16 code 125 - by Radioroslyn - 09-18-2016, 07:42 PM
RE: model 16 code 125 - by morzh - 09-18-2016, 09:30 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-18-2016, 10:34 PM
RE: model 16 code 125 - by Ron Ramirez - 09-20-2016, 09:48 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-19-2016, 10:33 PM
RE: model 16 code 125 - by Radioroslyn - 09-19-2016, 11:09 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 07:14 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 10:35 PM
RE: model 16 code 125 - by Radioroslyn - 09-20-2016, 11:14 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-20-2016, 11:34 PM
RE: model 16 code 125 - by Radioroslyn - 09-21-2016, 04:59 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-22-2016, 10:38 PM
RE: model 16 code 125 - by Radioroslyn - 09-23-2016, 01:01 AM
RE: model 16 code 125 - by Ron Ramirez - 09-23-2016, 06:01 AM
RE: model 16 code 125 - by Steve Davis - 09-23-2016, 08:54 AM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-23-2016, 05:00 PM
RE: model 16 code 125 - by Radioroslyn - 09-23-2016, 05:52 PM
RE: model 16 code 125 - by Kenneth F. Besso Jr. - 09-23-2016, 08:26 PM
RE: model 16 code 125 - by Ron Ramirez - 09-24-2016, 12:36 AM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-26-2016, 06:47 PM
RE: model 16 code 125 - by NostalgiaRadioTime - 09-27-2016, 10:35 PM
RE: model 16 code 125 - by morzh - 09-28-2016, 11:30 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4092 online users. [Complete List]
» 3 Member(s) | 4089 Guest(s)
