Wood Variety Question
This is the trim from around the bottom of my 38-93, I want to replace it because the corners are rounded pretty badly.
Does anyone know what wood species was used for this? It almost looks like Poplar but I really don't have a clue.
Thanks in advance.
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
Wood Variety Question - by Greenhorn - 09-23-2016, 12:49 PM
RE: Wood Variety Question - by Arran - 09-26-2016, 04:31 AM
RE: Wood Variety Question - by John Bartley - 09-26-2016, 07:39 AM
RE: Wood Variety Question - by Arran - 09-28-2016, 11:20 PM
RE: Wood Variety Question - by Greenhorn - 09-26-2016, 09:02 AM
Philco 91 Tuning Condenser
There are currently 9148 online users. [Complete List]
» 2 Member(s) | 9146 Guest(s)
