RCA Victrola V-210
Just noticed this now..
[Image: http://i292.photobucket.com/albums/mm38/...qvdu5u.jpg]
Looks like I will be replacing some wiring.. This is getting a little more involved now..
Skip...
RCA Victrola V-210 - by vecher - 09-09-2016, 11:59 AM
RE: RCA Victrola V-210 - by vecher - 09-09-2016, 02:43 PM
RE: RCA Victrola V-210 - by klondike98 - 09-09-2016, 02:57 PM
RE: RCA Victrola V-210 - by vecher - 09-09-2016, 07:31 PM
RE: RCA Victrola V-210 - by vecher - 09-18-2016, 10:59 PM
RE: RCA Victrola V-210 - by OldRestorer - 09-21-2016, 08:35 PM
RE: RCA Victrola V-210 - by morzh - 09-22-2016, 08:22 AM
RE: RCA Victrola V-210 - by vecher - 09-22-2016, 08:19 PM
RE: RCA Victrola V-210 - by vecher - 09-22-2016, 08:20 PM
RE: RCA Victrola V-210 - by Arran - 09-23-2016, 04:11 AM
RE: RCA Victrola V-210 - by morzh - 09-23-2016, 09:20 AM
RE: RCA Victrola V-210 - by Arran - 09-24-2016, 04:46 AM
RE: RCA Victrola V-210 - by vecher - 09-23-2016, 01:45 PM
RE: RCA Victrola V-210 - by morzh - 09-24-2016, 09:50 AM
RE: RCA Victrola V-210 - by vecher - 09-24-2016, 08:50 PM
RE: RCA Victrola V-210 - by vecher - 09-24-2016, 08:58 PM
RE: RCA Victrola V-210 - by KCMike - 09-24-2016, 09:09 PM
RE: RCA Victrola V-210 - by vecher - 09-24-2016, 09:55 PM
RE: RCA Victrola V-210 - by vecher - 10-13-2016, 12:17 PM
RE: RCA Victrola V-210 - by Radioroslyn - 10-13-2016, 03:13 PM
RE: RCA Victrola V-210 - by vecher - 10-13-2016, 09:23 PM
RE: RCA Victrola V-210 - by vecher - 10-15-2016, 12:28 AM
RE: RCA Victrola V-210 - by vecher - 10-16-2016, 10:35 AM
RE: RCA Victrola V-210 - by vecher - 10-17-2016, 11:12 PM
RE: RCA Victrola V-210 - by vecher - 10-18-2016, 03:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6094 online users. [Complete List]
» 1 Member(s) | 6093 Guest(s)
