Dial Stringing for 42-360
Restoring a philco radio mod- 42-360.So far i have all the electronics functioning however before i place it in the cabinet i need to replace the dial cord.Question:
Would the above diagram apply on a mod-42-360? [ed. this post was originally in the Tech Section and the diagram GIZMO is referring to is for models 14, 17, etc., klondike98] I'm thinking 30 gauge string but not sure. From diagram I do not see where the Frequency indicator comes in play?
It's a great radio for my man cave if i can finish the project? GIZMO
Dial Stringing for 42-360 - by GIZMO - 09-26-2016, 02:34 PM
RE: Dial Stringing for 42-360 - by KCMike - 09-26-2016, 06:29 PM
RE: Dial Stringing for 42-360 - by klondike98 - 09-30-2016, 03:17 PM
RE: Dial Stringing for 42-360 - by GIZMO - 10-03-2016, 03:47 PM
Restoring Philco 96
There are currently 7744 online users. [Complete List]
» 2 Member(s) | 7742 Guest(s)
