Dial Stringing for 42-360
You might try here if you haven't already.
http://www.theoldradiofixerupperguy.com/...0cord.html
Dial Stringing for 42-360 - by GIZMO - 09-26-2016, 02:34 PM
RE: Dial Stringing for 42-360 - by KCMike - 09-26-2016, 06:29 PM
RE: Dial Stringing for 42-360 - by klondike98 - 09-30-2016, 03:17 PM
RE: Dial Stringing for 42-360 - by GIZMO - 10-03-2016, 03:47 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6388 online users. [Complete List]
» 3 Member(s) | 6385 Guest(s)
