Aux input into a Philco 40-195
(09-27-2016, 10:09 AM)Tgace459 Wrote:  I'm interested in the idea of adding an AUX input into the Philco 40-195 console I'm working on in order to play vintage broadcasts via an MP3 player/cellphone.
At a cursory look I'm seeing a few people discussing wiring a jack into the volume pot. Is there anyone willing and able to give me a nutshell description of how that is (safely) done?
As "Paperboy" mentioned, take a look at a Zenith schematic. Nostalgia Air has all the Rider's scanned. Look for 5S119. It has factory add-on info on the schematic. I know because I have this model and it has the switch and phono input added. Works very well.  Icon_thumbup
The other option is to get an AM transmitter kit. I have the SSTRAN, and it works great. As long as your AM radio is restored and working properly, an AM transmitter is the way to go. No mods of the radio needed. Just tune it in like a normal station.... Icon_biggrin
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Aux input into a Philco 40-195 - by Tgace459 - 09-27-2016, 10:09 AM
RE: Aux input into a Philco 40-195 - by Paperboy - 09-27-2016, 11:33 AM
RE: Aux input into a Philco 40-195 - by PhilcoPhan1936 - 09-27-2016, 10:16 PM
RE: Aux input into a Philco 40-195 - by Arran - 10-03-2016, 04:36 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6352 online users. [Complete List]
» 3 Member(s) | 6349 Guest(s)
