Model 39-116
Welcome to the Phorum!
Icon_wave
A free schematic can be found on nostalgiaair.org
http://www.nostalgiaair.org/Resources/266/M0013266.htm
The Service Bulletin #310 is available on the audiophool site:
http://www.audiophool.com/Philco.html
( the reader for the djVu file is here; https://www.cuminas.jp/en/downloads/download/?pid=1 )
A more readable set of schematics and info can be had for a few bucks from Chuck.
www.philcorepairbench.com/schematics.htm
For more resources that might be helpful, see:
http://philcoradio.com/phorum/showthread.php?tid=14950
Model 39-116 - by troehl - 09-28-2016, 07:25 PM
RE: Model 39-116 - by klondike98 - 09-28-2016, 08:13 PM
RE: Model 39-116 - by troehl - 09-29-2016, 12:08 PM
RE: Model 39-116 - by Ozo - 10-17-2016, 01:41 PM
RE: Model 39-116 - by klondike98 - 10-17-2016, 09:59 PM
RE: Model 39-116 - by Ozo - 10-18-2016, 11:55 AM
RE: Model 39-116 - by NostalgiaRadioTime - 10-18-2016, 06:43 PM
RE: Model 39-116 - by Ozo - 10-18-2016, 07:23 PM
RE: Model 39-116 - by NostalgiaRadioTime - 10-18-2016, 09:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
