Philco signal tracer model 7030
I have one that I replaced the caps in and had to resolder the cable where it went into the probe. There is a tube in the probe.
I have not used it for troubleshooting yet but here is an instruction manual in case you don't have one.
http://www.myvintagetv.com/Apple%20PDF%2...Tester.pdf
Don't know if its better than Heath or Eico. Maybe someone can comment on that.
Philco signal tracer model 7030 - by Hank G - 09-29-2016, 02:14 PM
RE: Philco signal tracer model 7030 - by KCMike - 10-01-2016, 08:39 PM
RE: Philco signal tracer model 7030 - by Hank G - 10-05-2016, 04:29 PM
