6L6 tube substitute?
Just double check pin1 on the chassis to be sure it's not used as a tie point as it's connected directly to the metal shield on the 6L6.
6L6 tube substitute? - by sdradioman - 10-02-2016, 09:31 AM
RE: 6L6 tube substitute? - by Jim Koehler - 10-02-2016, 10:53 AM
RE: 6L6 tube substitute? - by klondike98 - 10-02-2016, 11:58 AM
RE: 6L6 tube substitute? - by Radioroslyn - 10-02-2016, 01:37 PM
RE: 6L6 tube substitute? - by Arran - 10-03-2016, 04:34 AM
RE: 6L6 tube substitute? - by Steve Davis - 10-03-2016, 09:31 AM
RE: 6L6 tube substitute? - by TA Forbes - 10-03-2016, 10:16 PM
RE: 6L6 tube substitute? - by Arran - 10-04-2016, 03:03 AM
RE: 6L6 tube substitute? - by TA Forbes - 10-07-2016, 09:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8540 online users. [Complete List]
» 3 Member(s) | 8537 Guest(s)
