Zenith 6D029
At 500mmf it isn't going do much. It's either there to decouple a small amount signal from the plate of the 12SQ7 or to add some negative feedback between the two audio stages. This would increase the bass response of the amp stage. If you happen to have a small value cap laying around connect it in parallel with that 500mmf and hear what happens. Either it will cut some of the high frequency in the audio or get a little boost to the lows. Happy experimenting!!!
You know I'm a hacker at this!!!!
ps Good Job!
Zenith 6D029 - by klondike98 - 09-25-2016, 07:42 PM
RE: Zenith 6D029 - by Paul Philco322 - 09-25-2016, 08:50 PM
RE: Zenith 6D029 - by klondike98 - 09-25-2016, 08:57 PM
RE: Zenith 6D029 - by klondike98 - 09-30-2016, 12:36 PM
RE: Zenith 6D029 - by Radioroslyn - 09-30-2016, 12:59 PM
RE: Zenith 6D029 - by klondike98 - 09-30-2016, 01:36 PM
RE: Zenith 6D029 - by klondike98 - 10-02-2016, 08:04 PM
RE: Zenith 6D029 - by Radioroslyn - 10-02-2016, 09:10 PM
RE: Zenith 6D029 - by klondike98 - 10-15-2016, 03:28 PM
RE: Zenith 6D029 - by OldRestorer - 10-15-2016, 03:48 PM
RE: Zenith 6D029 - by Kenneth F. Besso Jr. - 10-15-2016, 09:36 PM
RE: Zenith 6D029 - by KCMike - 10-15-2016, 10:11 PM
RE: Zenith 6D029 - by Paul Philco322 - 10-31-2016, 08:52 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 9997 online users. [Complete List]
» 2 Member(s) | 9995 Guest(s)
