Model 80 Mods
What it does is add some osc signal (from the 36's cathode) to the input of the mixer. This improves the ability to the mixer to handle stronger signals without overload and generally improves the mixing action.
By touching the volume control you are asenually are bypassing it and adding more rf signal, that's why it gets louder.
Model 80 Mods - by Mike L - 10-03-2016, 06:45 PM
RE: Model 80 Mods - by Radioroslyn - 10-03-2016, 07:15 PM
RE: Model 80 Mods - by Mike L - 10-08-2016, 01:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6345 online users. [Complete List]
» 3 Member(s) | 6342 Guest(s)
