Tube tester covered with Tolex
I just pick a Precise 111 up,,from antique store $20.00,,,someone ,,did a real hack job on it,,,got terminals ,,all over the middle top section,,,Have not gottin into it yet,,,
Tube tester covered with Tolex - by TV MAN - 05-27-2016, 11:24 AM
RE: Tube tester covered with Tolex - by Arran - 05-29-2016, 03:03 AM
RE: Tube tester covered with Tolex - by TV MAN - 05-30-2016, 05:24 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-13-2016, 06:24 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-14-2016, 04:25 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-20-2016, 03:10 PM
RE: Tube tester covered with Tolex - by sam - 08-20-2016, 03:23 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-25-2016, 12:15 AM
RE: Tube tester covered with Tolex - by Geoff - 08-27-2016, 02:20 PM
RE: Tube tester covered with Tolex - by TA Forbes - 10-03-2016, 10:26 PM
RE: Tube tester covered with Tolex - by Kenneth F. Besso Jr. - 10-04-2016, 06:00 PM
RE: Tube tester covered with Tolex - by TA Forbes - 10-07-2016, 09:22 PM
There are currently 5460 online users. [Complete List]
» 2 Member(s) | 5458 Guest(s)
