Halson Radio
Hey Eric,
Methinks your vc circuit should be closer to this:
http://www.nostalgiaair.org/pagesbymodel...008952.pdf
A lot of the old TRF sets the vc on one end is tied the ant and the other the the cathode circuit of the rf amps, wiper is grounded.
How it works is as you turn the vc down it lessens to resistance from the ant to the chassis esscenually shorting the ant to ground. And at the same time it's also increasing the resistance of the rf amps cathodes to ground raising the cathode voltage higher which lowers the gain.
Conversely turning the vc up allows more signal to pass though the vc from the antenna and brings the cathodes in the rf amps closer to ground which increases the rf gain.
Repeat after me, no IF no IF no local oscillator no local oscillator.
GL my friend
Halson Radio - by Eric - 10-03-2016, 10:05 AM
RE: Halson Radio - by morzh - 10-03-2016, 11:37 AM
RE: Halson Radio - by Eric - 10-03-2016, 03:49 PM
RE: Halson Radio - by morzh - 10-03-2016, 05:16 PM
RE: Halson Radio - by Eric - 10-03-2016, 07:39 PM
RE: Halson Radio - by KCMike - 10-03-2016, 05:49 PM
RE: Halson Radio - by Eric - 10-03-2016, 07:38 PM
RE: Halson Radio - by Radioroslyn - 10-03-2016, 07:27 PM
RE: Halson Radio - by Kenneth F. Besso Jr. - 10-03-2016, 09:02 PM
RE: Halson Radio - by morzh - 10-03-2016, 09:32 PM
RE: Halson Radio - by Arran - 10-04-2016, 03:38 AM
RE: Halson Radio - by morzh - 10-04-2016, 07:58 AM
RE: Halson Radio - by OldRestorer - 10-04-2016, 08:58 AM
RE: Halson Radio - by morzh - 10-04-2016, 12:38 PM
RE: Halson Radio - by Eric - 10-04-2016, 02:36 PM
RE: Halson Radio - by Eric - 10-05-2016, 04:29 PM
RE: Halson Radio - by Radioroslyn - 10-05-2016, 05:58 PM
RE: Halson Radio - by Eric - 10-06-2016, 05:48 PM
RE: Halson Radio - by Radioroslyn - 10-06-2016, 06:22 PM
RE: Halson Radio - by Eric - 10-07-2016, 01:28 PM
RE: Halson Radio - by Radioroslyn - 10-07-2016, 01:54 PM
RE: Halson Radio - by TA Forbes - 10-07-2016, 08:51 PM
RE: Halson Radio - by Arran - 10-11-2016, 04:20 AM
Philco 89 indicator light.
There are currently 4216 online users. [Complete List]
» 3 Member(s) | 4213 Guest(s)
