  • 1 Vote(s) - 1 Average
Help identifying radio
http://radioatticarchives.com/radio.htm?radio=8082
This is 66.
As you can see, the cabinet is the same.
But as Ron said, it is a 60.
Help identifying radio - by pete_b - 10-06-2016, 11:28 AM
RE: Help identifying radio - by morzh - 10-06-2016, 01:15 PM
RE: Help identifying radio - by Radioroslyn - 10-06-2016, 04:24 PM
RE: Help identifying radio - by klondike98 - 10-06-2016, 05:12 PM
RE: Help identifying radio - by Ron Ramirez - 10-06-2016, 06:31 PM
RE: Help identifying radio - by morzh - 10-06-2016, 09:35 PM
RE: Help identifying radio - by Ron Ramirez - 10-06-2016, 09:56 PM
RE: Help identifying radio - by Radioroslyn - 10-06-2016, 10:12 PM
RE: Help identifying radio - by Radioroslyn - 10-06-2016, 10:35 PM
RE: Help identifying radio - by pete_b - 10-07-2016, 02:30 PM
RE: Help identifying radio - by TA Forbes - 10-07-2016, 08:59 PM
RE: Help identifying radio - by Ron Ramirez - 10-07-2016, 09:31 PM
RE: Help identifying radio - by morzh - 10-08-2016, 09:25 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6855 online users. [Complete List]
» 1 Member(s) | 6854 Guest(s)
