VERY basic 41-315 questions
Hi Rick. Welcome. It has had some work done on it. The two large orange looking electrolytic caps on left and the two orange smaller caps in center are newer. Over all it doesn't look too bad except you do have some rubber covered wire that is rotted. The other older paper caps should be replaced also.
I see Terry answered while I was slowly responding
VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 02:25 PM
RE: VERY basic 41-315 questions - by Radioroslyn - 10-09-2016, 03:24 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 05:21 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 05:45 PM
RE: VERY basic 41-315 questions - by Radioroslyn - 10-09-2016, 06:42 PM
RE: VERY basic 41-315 questions - by KCMike - 10-09-2016, 06:51 PM
RE: VERY basic 41-315 questions - by DeckApe - 10-09-2016, 07:04 PM
RE: VERY basic 41-315 questions - by Radioroslyn - 10-09-2016, 07:06 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 07:23 PM
RE: VERY basic 41-315 questions - by bfrohwein - 10-12-2016, 10:10 PM
RE: VERY basic 41-315 questions - by bfrohwein - 10-12-2016, 10:12 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-15-2016, 01:03 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-21-2016, 07:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9248 online users. [Complete List]
» 3 Member(s) | 9245 Guest(s)
