VERY basic 41-315 questions
So Rick if you want to take the bull by the horns the service info can be found here:
 http://www.nostalgiaair.org/Resources/423/M0013423.htm
You don't need to worry about all the funny drawing w/squiggly lines, just the last page with the component layout. You can use it the reference each parts value and placement. A few hand tools and some soldering skilsl and your all set. Can help guide you as you go along. Or if you happen to be in the hood swing by!
+1 Ape Long time no post, good to hear from WA.
VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 02:25 PM
RE: VERY basic 41-315 questions - by Radioroslyn - 10-09-2016, 03:24 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 05:21 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 05:45 PM
RE: VERY basic 41-315 questions - by Radioroslyn - 10-09-2016, 06:42 PM
RE: VERY basic 41-315 questions - by KCMike - 10-09-2016, 06:51 PM
RE: VERY basic 41-315 questions - by DeckApe - 10-09-2016, 07:04 PM
RE: VERY basic 41-315 questions - by Radioroslyn - 10-09-2016, 07:06 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-09-2016, 07:23 PM
RE: VERY basic 41-315 questions - by bfrohwein - 10-12-2016, 10:10 PM
RE: VERY basic 41-315 questions - by bfrohwein - 10-12-2016, 10:12 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-15-2016, 01:03 PM
RE: VERY basic 41-315 questions - by Rick41-315 - 10-21-2016, 07:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8153 online users. [Complete List]
» 3 Member(s) | 8150 Guest(s)
