41-295 rubber wire
Heat shrinkable to me is a remedy for cases when nothing else works. Like a rubber wire going into a potted transformer or a coil.
In chassis, point to point, I would re-wire what I could.
Typically AWG 20 is a pretty universal gauge; in large radios where tubes use lots of current for filaments, like 2-5A strictly for those I would use AWG18.
41-295 rubber wire - by Paperboy - 10-10-2016, 12:53 PM
RE: 41-295 rubber wire - by klondike98 - 10-10-2016, 02:26 PM
RE: 41-295 rubber wire - by Paperboy - 10-10-2016, 02:55 PM
RE: 41-295 rubber wire - by klondike98 - 10-10-2016, 03:05 PM
RE: 41-295 rubber wire - by morzh - 10-10-2016, 05:49 PM
RE: 41-295 rubber wire - by Paperboy - 10-11-2016, 03:27 PM
RE: 41-295 rubber wire - by morzh - 10-11-2016, 03:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3935 online users. [Complete List]
» 3 Member(s) | 3932 Guest(s)
