No manual tuning, only presets 40-180
So does tune manually on SW???
RE: No manual tuning, only presets 40-180 - by Radioroslyn - 10-12-2016, 02:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4870 online users. [Complete List]
» 2 Member(s) | 4868 Guest(s)
