Philco RP-1 restoration Chronicle
I like to start over when mistakes are made. If I took some time to try and fix runs and uneven coating then sand through it by accident I would be really mad so I just strip and start over... I want it uniform and it was not.. I think I have the colors you mention but the 3015 walnut oak toner has red in it. I dont really see red in the original job. The 7020 walnut has no red...
I will just test them and strip if necessary.. Wood is forgiving...Thankfully, Icon_lol
Thanks for the help Ron.
RE: Philco RP-1 restoration Chronicle - by OldRestorer - 10-12-2016, 07:06 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-12-2016, 07:29 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-12-2016, 10:14 PM
RE: Philco RP-1 restoration Chronicle - by KCMike - 10-24-2016, 06:53 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-24-2016, 10:43 PM
RE: Philco RP-1 restoration Chronicle - by vecher - 10-24-2016, 11:35 PM
RE: Philco RP-1 restoration Chronicle - by morzh - 10-25-2016, 09:59 AM
RE: Philco RP-1 restoration Chronicle - by morzh - 10-25-2016, 02:27 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-25-2016, 07:50 PM
Philco 91 Tuning Condenser
There are currently 10125 online users. [Complete List]
» 2 Member(s) | 10123 Guest(s)
