Philco RP-1 restoration Chronicle
I would but I just got a box FULL of cartridges in the mail  Icon_e_surprised Icon_crazy
You said you wanted the RP-2 without a lid. This is an RP-1
Now I have to go out to the cold shed and start rebuilding carts at night and doing cabinets during the day...
ACK!
RE: Philco RP-1 restoration Chronicle - by sam - 10-12-2016, 07:29 PM
RE: Philco RP-1 restoration Chronicle - by OldRestorer - 10-12-2016, 07:54 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-12-2016, 10:14 PM
RE: Philco RP-1 restoration Chronicle - by KCMike - 10-24-2016, 06:53 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-24-2016, 10:43 PM
RE: Philco RP-1 restoration Chronicle - by vecher - 10-24-2016, 11:35 PM
RE: Philco RP-1 restoration Chronicle - by morzh - 10-25-2016, 09:59 AM
RE: Philco RP-1 restoration Chronicle - by morzh - 10-25-2016, 02:27 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-25-2016, 07:50 PM
Philco 91 Tuning Condenser
There are currently 10073 online users. [Complete List]
» 1 Member(s) | 10072 Guest(s)
