No manual tuning, only presets 40-180
If you can get it to operate on SW then your tuning cap isn't the issue. I'm thinking that 18mc is at the high end of the SW band. How about in the middle or low end? There is more of a possibility for the plates to be shorting. Typically if the 6J8 mixer is going to be a problem it will be at higher frequencies, like on SW verses the BCB.
RE: No manual tuning, only presets 40-180 - by Radioroslyn - 10-12-2016, 08:56 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7547 online users. [Complete List]
» 3 Member(s) | 7544 Guest(s)
