1932 Simplex Model N in Green/White
I've picked up a few of these sets over the years and thought I would consolidate the various bits and pieces. One one these is a cabinet that has a fair a mount veneer damage and was painted first white then green. Ended up scraping it down w/a snap blade knife to get the white off. Still need to clean it up with some oms to remove the left over white. They would be considered midgets as they are about half the size of a Philco 20 or 21.  https://www.flickr.com/photos/53710524@N...ateposted/
1932 Simplex Model N in Green/White - by Radioroslyn - 10-12-2016, 09:42 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
