Philco RP-1 restoration Chronicle
Terry, A blade?? really!
Bret.... If these come out good I will of course do yours.
Sam.. Cartridges are small.. Lots of them fit in a "Very tiny box"  Icon_evil
Next time keep the cartridges apart.. They multiplied from the last time, Icon_lol
Me
RE: Philco RP-1 restoration Chronicle - by sam - 10-12-2016, 07:29 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-12-2016, 10:14 PM
RE: Philco RP-1 restoration Chronicle - by OldRestorer - 10-13-2016, 12:24 AM
RE: Philco RP-1 restoration Chronicle - by KCMike - 10-24-2016, 06:53 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-24-2016, 10:43 PM
RE: Philco RP-1 restoration Chronicle - by vecher - 10-24-2016, 11:35 PM
RE: Philco RP-1 restoration Chronicle - by morzh - 10-25-2016, 09:59 AM
RE: Philco RP-1 restoration Chronicle - by morzh - 10-25-2016, 02:27 PM
RE: Philco RP-1 restoration Chronicle - by sam - 10-25-2016, 07:50 PM
Philco 91 Tuning Condenser
There are currently 8209 online users. [Complete List]
» 3 Member(s) | 8206 Guest(s)
