What Philco is This?
(10-14-2016, 10:57 PM)markmokris Wrote:
(10-14-2016, 06:23 PM)PhilcoPhan1936 Wrote:  Nice. Not sure I want to see the under-chassis! I can imagine it's pretty crowded!
Not sure if I remember.  Did you restore a 116 Jeff?
I snap some pictures when I get it apart.  Probably will be a while though.
Mark
Nope, I have never laid eyes on one, unfortunately. I can imagine being a 11 tube model that there's a lot going on under that chassis though!
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
What Philco is This? - by markmokris - 10-14-2016, 03:37 PM
RE: What Philco is This? - by markmokris - 10-14-2016, 04:01 PM
RE: What Philco is This? - by Ron Ramirez - 10-15-2016, 07:59 AM
RE: What Philco is This? - by Paul Philco322 - 10-14-2016, 04:07 PM
RE: What Philco is This? - by markmokris - 10-14-2016, 05:30 PM
RE: What Philco is This? - by Arran - 10-18-2016, 03:17 AM
RE: What Philco is This? - by morzh - 10-14-2016, 04:31 PM
RE: What Philco is This? - by PhilcoPhan1936 - 10-14-2016, 06:23 PM
RE: What Philco is This? - by markmokris - 10-14-2016, 10:57 PM
RE: What Philco is This? - by PhilcoPhan1936 - 10-15-2016, 02:45 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
