Philco 610 Volume Control Taper
I replaced a bad volume control in a Philco 610 with a 500 audio taper potentiometer. Now I find that the set is at almost ear piercing volume at just a mere 10% travel.
http://www.nostalgiaair.org/pagesbymodel...013797.pdf
Do these radios NOT use an audio taper? Is that my problem?
I bought some 500K audio taper potentiometers on eBay. I assume I was sold audio taper pots.
Mark
Philco 610 Volume Control Taper - by markmokris - 10-16-2016, 07:56 PM
RE: Philco 610 Volume Control Taper - by morzh - 10-16-2016, 08:40 PM
RE: Philco 610 Volume Control Taper - by morzh - 10-17-2016, 10:31 AM
Restoring Philco 96
There are currently 7513 online users. [Complete List]
» 2 Member(s) | 7511 Guest(s)
